Bose QuietComfort 35 Earpad Replacement
  1. Bose QuietComfort 35 Earpad Replacement, Earpad: step 1, image 1 of 3 Bose QuietComfort 35 Earpad Replacement, Earpad: step 1, image 2 of 3 Bose QuietComfort 35 Earpad Replacement, Earpad: step 1, image 3 of 3
    • Reach a thumb under the damaged foam earpad and pull to remove from headphones.
  2. Bose QuietComfort 35 Earpad Replacement: step 2, image 1 of 3 Bose QuietComfort 35 Earpad Replacement: step 2, image 2 of 3 Bose QuietComfort 35 Earpad Replacement: step 2, image 3 of 3
    • Locate the plastic oval ring attached to the foam ear pad.
    • Gently pull apart the plastic ring and leather fabric until separated.
  3. Bose QuietComfort 35 Earpad Replacement: step 3, image 1 of 3 Bose QuietComfort 35 Earpad Replacement: step 3, image 2 of 3 Bose QuietComfort 35 Earpad Replacement: step 3, image 3 of 3
    • Rip the leather exterior until green foam is visible.
    • Remove green foam.
    • Dispose of damaged leather.
  4. Bose QuietComfort 35 Earpad Replacement: step 4, image 1 of 3 Bose QuietComfort 35 Earpad Replacement: step 4, image 2 of 3 Bose QuietComfort 35 Earpad Replacement: step 4, image 3 of 3
    • Print the linked pattern.
    • Cut out the pattern using the solid black lines.
    • Trace the pattern onto the new leather.
  5. Bose QuietComfort 35 Earpad Replacement: step 5, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 5, image 2 of 2
    • Cut out the leather following the traced lines.
  6. Bose QuietComfort 35 Earpad Replacement: step 6, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 6, image 2 of 2
    • Using the pattern as a guide, mark holes on the smaller donut with a pencil
    • Punch holes with the leather punch tool
  7. Bose QuietComfort 35 Earpad Replacement: step 7, image 1 of 3 Bose QuietComfort 35 Earpad Replacement: step 7, image 2 of 3 Bose QuietComfort 35 Earpad Replacement: step 7, image 3 of 3
    • Align the smaller donut on top of the larger donut
    • Make sure the leather right sides (the side of the leather you want to show) are facing each other
    • Using a thread and a needle, sew the two donuts together at the center of the donut using a whip stitch
  8. Bose QuietComfort 35 Earpad Replacement: step 8, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 8, image 2 of 2
    • Turn the donut inside out
    • Make sure the leather right sides (the side of the leather you want to show) are facing away from each other
  9. Bose QuietComfort 35 Earpad Replacement: step 9, image 1 of 3 Bose QuietComfort 35 Earpad Replacement: step 9, image 2 of 3 Bose QuietComfort 35 Earpad Replacement: step 9, image 3 of 3
    • Buff the outer edge of the small donut with a nail file
    • Glue the outer edge of the small donut with fabric glue
    • Leave the glue to dry for 5 minutes
  10. Bose QuietComfort 35 Earpad Replacement: step 10, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 10, image 2 of 2
    • Buff the inner edge of the plastic ring
    • Glue the inner edge of the plastic ring
  11. Bose QuietComfort 35 Earpad Replacement: step 11, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 11, image 2 of 2
    • Attach the plastic ring (glue side down) to the smaller donut
    • Leave to dry for 20 minutes
  12. Bose QuietComfort 35 Earpad Replacement: step 12, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 12, image 2 of 2
    • Slide the leather ring through the cushion, leaving the plastic ring on the other side
  13. Bose QuietComfort 35 Earpad Replacement: step 13, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 13, image 2 of 2
    • Apply glue to the edges of the leather donut
    • Put an object in between the donut for a better drying process
    • Leave to dry for 5 minutes
  14. Bose QuietComfort 35 Earpad Replacement: step 14, image 1 of 3 Bose QuietComfort 35 Earpad Replacement: step 14, image 2 of 3 Bose QuietComfort 35 Earpad Replacement: step 14, image 3 of 3
    • Fold the leather down to the plastic ring, wrapping around the cushion ring
    • Straighten out the creases in the leather ring
  15. Bose QuietComfort 35 Earpad Replacement: step 15, image 1 of 2 Bose QuietComfort 35 Earpad Replacement: step 15, image 2 of 2
    • Use a paper clip to hold the pieces in place while letting glue dry
  16. Bose QuietComfort 35 Earpad Replacement: step 16, image 1 of 3 Bose QuietComfort 35 Earpad Replacement: step 16, image 2 of 3 Bose QuietComfort 35 Earpad Replacement: step 16, image 3 of 3
    • Attach the leather earpads back onto the headphone
    • Apply light pressure to secure the earpads into place
2 other people completed this guide.
Attached Documents
Johnson Ou
298 Reputation
1 Guide authored
UC Davis, Team 4-2, Andersen Winter 2024 Member of UC Davis, Team 4-2, Andersen Winter 2024
UCD-ANDERSEN-W24S4G2
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 103
