Bose Solo 5 Sound Bar Control Panel Replacement
  1. Bose Solo 5 Sound Bar Control Panel Replacement, Control Panel: step 1, image 1 of 1
    • Lay Bose Solo 5 with speakers facing away from you and bottom side facing upward.
  2. Bose Solo 5 Sound Bar Control Panel Replacement: step 2, image 1 of 2 Bose Solo 5 Sound Bar Control Panel Replacement: step 2, image 2 of 2
    • Remove the five 18.25mm screws with the Phillips #2 screw driver.
  3. Bose Solo 5 Sound Bar Control Panel Replacement: step 3, image 1 of 1
    • Remove the gold plates snap connector from the circuit board by pulling it apart.
  4. Bose Solo 5 Sound Bar Control Panel Replacement: step 4, image 1 of 1
    • Using the plastic opening tool, lift the circuit board up and remove from housing.
  5. Bose Solo 5 Sound Bar Control Panel Replacement: step 5, image 1 of 2 Bose Solo 5 Sound Bar Control Panel Replacement: step 5, image 2 of 2
    • Disconnect the cords running to the white connecter by pulling up on the tab until it is disconnected completely.
Emma
500 Reputation
3 Guides authored
5 Comments
Does anyone know where to buy a replacement logic board? I’ve been searching for a while now, no dice.
Tyler Barney - Reply
hallo und wo bekomme ich das Ersatzteil die Platiene 73252 Delta 3
APP TISCHNER - Reply
Has anyone had any luck finding the same board. Im looking.
ka.wells - Reply
I know how to open it. What I don't know is where to buy one.
szanti - Reply
If anyone was able to find the board, it wuold be great to know where did you find it. Looking for this board during months...
Juan Ramirez - Reply
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 115
All Time: 13,045
