Bose Solo 5 Sound Bar Speaker Replacement
Chase Cooper
Chase Cooper and 3 other contributors
Last updated on September 15, 2020
15 - 20 minutes
Easy
Introduction
Go to step 1
If your Bose Solo 5 Sound Bar speaker is damaged or malfunctioning, this guide will walk you through how to replace the speaker so that the sound bar is properly functioning again.
The speakers in the Bose Solo 5 Sound Bar are responsible for producing quality audio. If a speaker is damaged, the audio coming from the sound bar might be distorted or impaired.
Before using the following guide, make sure that there isn’t any buildup of dirt, dust, or other debris that could possibly be inhibiting the audio. If this is the case, an ESD-safe brush or small dust blower usually can be used to remove the debris.
Prior to starting the guide, make sure to power off the device and remove it from connection to any sources of electricity.
Tools
  1. Bose Solo 5 Sound Bar Speaker Replacement, Speaker: step 1, image 1 of 1
    • Lay Bose Solo 5 on its top side with the speakers facing away from you.
  2. Bose Solo 5 Sound Bar Speaker Replacement: step 2, image 1 of 2 Bose Solo 5 Sound Bar Speaker Replacement: step 2, image 2 of 2
    • Remove the two screws located at the outer edge of the backside with a Phillips head screwdriver.
  3. Bose Solo 5 Sound Bar Speaker Replacement: step 3, image 1 of 1
    • Lay the speaker on its backside with the speakers facing up. Wedge the plastic opening tool into the crack where the protective wire screen meets the housing. Pry apart until you create enough room for your fingers.
  4. Bose Solo 5 Sound Bar Speaker Replacement: step 4, image 1 of 2 Bose Solo 5 Sound Bar Speaker Replacement: step 4, image 2 of 2
    • Pull the screen gently away from the housing to reveal the two speakers with your fingers.
  5. Bose Solo 5 Sound Bar Speaker Replacement: step 5, image 1 of 3 Bose Solo 5 Sound Bar Speaker Replacement: step 5, image 2 of 3 Bose Solo 5 Sound Bar Speaker Replacement: step 5, image 3 of 3
    • Remove the 4 screws in each corner of the speaker to remove it from the housing.
  6. Bose Solo 5 Sound Bar Speaker Replacement: step 6, image 1 of 2 Bose Solo 5 Sound Bar Speaker Replacement: step 6, image 2 of 2
    • Peel back the styrofoam on the speaker & disconnect the yellow & brown wires by sliding them off the receptor.
3 other people completed this guide.
Chase Cooper
226 Reputation
1 Guide authored
One Comment
Well opening the case affect its original sound tuning or will it affect the performance ?
Saket Adhau - Reply
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 134
All Time: 14,223
