Bose SoundDock Portable v2 IR Receiver Replacement
  1. Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 1 of 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 2 of 3 Bose SoundDock Portable v2 IR Receiver Replacement, IR Receiver: step 1, image 3 of 3
    • Gently pry the front mesh cover off of the sound dock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart.
  2. Bose SoundDock Portable v2 IR Receiver Replacement: step 2, image 1 of 1
    • Using a T15 torx screwdriver, remove the 8mm screw holding the IR sensor to the speaker system.
  3. Bose SoundDock Portable v2 IR Receiver Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers or your fingers, gently remove the ribbon cable connecting the IR sensor to the system.
2 other people completed this guide.
Evan Low
551 Reputation
4 Guides authored
Cal Poly, Team 4-1, Maness Spring 2015 Member of Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Members
5 Guides authored
One Comment
Hi my sounddock blocked suddenly and the green led always on. Do you now something about please... :(
jose - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 36
All Time: 6,837
