Bose SoundDock Portable v2 Speaker Replacement
  1. Bose SoundDock Portable v2 Speaker Replacement, Speaker: step 1, image 1 of 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: step 1, image 2 of 3 Bose SoundDock Portable v2 Speaker Replacement, Speaker: step 1, image 3 of 3
    • Gently pry the front mesh cover off of the SoundDock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart
  2. Bose SoundDock Portable v2 Speaker Replacement: step 2, image 1 of 2 Bose SoundDock Portable v2 Speaker Replacement: step 2, image 2 of 2
    • Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
    • Gently lift the speaker from the base.
    • Do not lift the speaker to far out of the base, you may damage the wires.
  3. Bose SoundDock Portable v2 Speaker Replacement: step 3, image 1 of 1
    • You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
4 other people completed this guide.
Evan Low
551 Reputation
4 Guides authored
Cal Poly, Team 4-1, Maness Spring 2015 Member of Cal Poly, Team 4-1, Maness Spring 2015
CPSU-MANESS-S15S4G1
4 Members
5 Guides authored
5 Comments
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
vero198099 - Reply
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
AJ Grape - Reply
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Colm Donnelly -
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
Chantelle Webb - Reply
How do you cut on without remote
Chad Davenport - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 11,817
