Bose SoundLink Color II Battery Replacement
  1. Bose SoundLink Color II Battery Replacement, Battery: step 1, image 1 of 1
    • Start by pulling on the outer edges of the rubber part on the bottom of the enclosure.
    • Note that it will not detach completely from the enclosure.
  2. Bose SoundLink Color II Battery Replacement: step 2, image 1 of 2 Bose SoundLink Color II Battery Replacement: step 2, image 2 of 2
    • Pry between the black hard plastic base and the colored rubber casing of your speaker.
    • The bottom of the speaker unclips, and you have access to the rings that hold the colored envelope.
  3. Bose SoundLink Color II Battery Replacement: step 3, image 1 of 1
    • Pull on the colored envelope, folding it on itself outwards.
    • By removing the cover, the protective foam of the microphone will be damaged, the water resistance will be impacted.
  4. Bose SoundLink Color II Battery Replacement: step 4, image 1 of 2 Bose SoundLink Color II Battery Replacement: step 4, image 2 of 2
    • Remove the 7 screws on the back of the enclosure.
    • And you access the interior of the enclosure (the battery has already been replaced in the photo shown).
  5. Bose SoundLink Color II Battery Replacement: step 5, image 1 of 1
    • Cleanly cut the foam and battery wrap.
    • The foam and the envelope will be used for reassembly (to avoid vibrations).
    • Be careful not to puncture the battery or it may catch fire.
  6. Bose SoundLink Color II Battery Replacement: step 6, image 1 of 1
    • Unsolder the two legs of the battery and take out the battery.
  7. Bose SoundLink Color II Battery Replacement: step 7, image 1 of 1
    • Solder the new battery, and replace the envelope with the foam, holding everything with tape.
    • For reassembly, follow this guide in reverse order.
To reassemble your device, follow the instructions in reverse order.
10 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
yellowjellyfish
707 Reputation
2 Guides authored
4 Guide Comments
Please be advised that the Bose support website has a firmware update that fixes some battery issues. I took my dead - non-charging Soundlink Color II apart and then found the website and fixed the issue with the firmware update! The update website is located @ http://btu.bose.com
paul ramirez - Reply
Beware that, after the battery gets undervolted (like 2.4V), the device does not seem to accept an externally charged battery and continues to act dead, until it finds some form of comfort over its USB input. Not from a dumb 5V power supply, but from an USB charger or PC supporting some level of power delivery extension, and an appropriately wired lead.
Stein Somers - Reply
Please list type of battery and where to find it it took me a while to find it
Bootyclapper69 - Reply
Guide was good, the battery pcb i found in my unit was a bit different and had metal strips soldered to the board and welded to the battery.
Seifeldin Hashem - Reply
Past 24 Hours: 25
Past 7 Days: 171
Past 30 Days: 601
All Time: 29,261
