Bose SoundLink III Treble Speakers Replacement
Dakoda Sanders
Dakoda Sanders and 2 other contributors
Last updated on May 7, 2024
15 - 20 minutes
Moderate
Introduction
Go to step 1
If you are experiencing any audio issues with the higher frequency sounds (the treble) such as distortion, muffling, quietness, or total absence of sound, you may need to replace one or more of your treble speakers.
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. Bose SoundLink III Treble Speakers Replacement, Battery: step 1, image 1 of 1
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose SoundLink III Treble Speakers Replacement: step 2, image 1 of 2 Bose SoundLink III Treble Speakers Replacement: step 2, image 2 of 2
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose SoundLink III Treble Speakers Replacement: step 3, image 1 of 1
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose SoundLink III Treble Speakers Replacement: step 4, image 1 of 2 Bose SoundLink III Treble Speakers Replacement: step 4, image 2 of 2
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
  5. Bose SoundLink III Treble Speakers Replacement, Motherboard: step 5, image 1 of 1
    • Gently peel back the adhesive padding on either side of the inner back panel.
    • The adhesive for these pads is powerful, but you may require new adhesive if the original begins to fail.
  6. Bose SoundLink III Treble Speakers Replacement: step 6, image 1 of 2 Bose SoundLink III Treble Speakers Replacement: step 6, image 2 of 2
    • Remove the four 12.5 mm Phillips #2 screws mounting the outer case.
    • Slide off the outer case.
  7. Bose SoundLink III Treble Speakers Replacement: step 7, image 1 of 1
    • Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
    • All screws (excluding the two middle screws on the right side) are 12.5 mm in length. The aforementioned middle screws are 21 mm.
  8. Bose SoundLink III Treble Speakers Replacement: step 8, image 1 of 2 Bose SoundLink III Treble Speakers Replacement: step 8, image 2 of 2
    • Remove the two 12.5 mm screws which mount the top panel using a Phillips #2 screwdriver.
    • Now you should be able to lift the top panel off.
  9. Bose SoundLink III Treble Speakers Replacement: step 9, image 1 of 2 Bose SoundLink III Treble Speakers Replacement: step 9, image 2 of 2
    • Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
    • The circuitry for the buttons on the top panel may be found underneath, so use caution not to damage it.
  10. Bose SoundLink III Treble Speakers Replacement: step 10, image 1 of 1
    • Remove the 12.5 mm screw mounting the motherboard using a Philips #2 screwdriver.
  11. Bose SoundLink III Treble Speakers Replacement: step 11, image 1 of 1
    • Gently disconnect the three cables connected to the motherboard.
    • Remove the motherboard from the device.
  12. Bose SoundLink III Treble Speakers Replacement, Speakers: step 12, image 1 of 2 Bose SoundLink III Treble Speakers Replacement, Speakers: step 12, image 2 of 2
    Tool used on this step:
    • For each of the 4 treble speakers you must uncoil the red wire and black wire in order to remove them.
    • You may need metal tweezers in order to re-coil the replacement speaker.
5 other people completed this guide.
Dakoda Sanders
1,558 Reputation
4 Guides authored
USF Tampa, Team 3-2, Wollert Spring 2016 Member of USF Tampa, Team 3-2, Wollert Spring 2016
USFT-WOLLERT-S16S3G2
4 Members
8 Guides authored
One Comment
Hi,
Where can i buy the replacement speakers?
Scott - Reply
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 34
All Time: 4,971
