Bose SoundLink Mini Front/Back Protective Grille Replacement
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: step 1, image 1 of 1
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: step 2, image 1 of 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: step 2, image 2 of 2
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: step 3, image 1 of 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: step 3, image 2 of 2
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: step 4, image 1 of 2 Bose SoundLink Mini Front/Back Protective Grille Replacement: step 4, image 2 of 2
    • Repeat steps to remove the back grille.
9 other people completed this guide.
Jordan Smith
895 Reputation
4 Guides authored
Cal Poly, Team 1-23, Maness Fall 2015 Member of Cal Poly, Team 1-23, Maness Fall 2015
CPSU-MANESS-F15S1G23
4 Members
21 Guides authored
6 Comments
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Reply
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Reply
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Reply
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Reply
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 99
All Time: 12,772
