Bose SoundTouch 10 Bass Port Replacement
  1. Bose SoundTouch 10 Bass Port Replacement, Front Panel: step 1, image 1 of 1
    • Turn the speaker over so that the rubber strips along the bottom are facing you.
    • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
  2. Bose SoundTouch 10 Bass Port Replacement: step 2, image 1 of 1
    • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
  3. Bose SoundTouch 10 Bass Port Replacement: step 3, image 1 of 2 Bose SoundTouch 10 Bass Port Replacement: step 3, image 2 of 2
    • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
    • Lift the panel away to reveal the speaker head.
  4. Bose SoundTouch 10 Bass Port Replacement, Back panel: step 4, image 1 of 1
    • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
  5. Bose SoundTouch 10 Bass Port Replacement: step 5, image 1 of 1
    • Flip the speaker onto its back.
    • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
  6. Bose SoundTouch 10 Bass Port Replacement: step 6, image 1 of 2 Bose SoundTouch 10 Bass Port Replacement: step 6, image 2 of 2
    • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
    • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
    • Once the panel has been disconnected, it should fall open revealing the motherboard.
  7. Bose SoundTouch 10 Bass Port Replacement: step 7, image 1 of 2 Bose SoundTouch 10 Bass Port Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
  8. Bose SoundTouch 10 Bass Port Replacement: step 8, image 1 of 2 Bose SoundTouch 10 Bass Port Replacement: step 8, image 2 of 2
    • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
    • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
  9. Bose SoundTouch 10 Bass Port Replacement, Bass Port: step 9, image 1 of 1
    • Use a #0 Phillips screwdriver to remove each of the two 11mm screws attached to the bass port.
  10. Bose SoundTouch 10 Bass Port Replacement: step 10, image 1 of 1
    • Lift the bass port away from the motherboard.
2 other people completed this guide.
James Asbury
898 Reputation
5 Guides authored
Cal Poly, Team S13-G1, Forte Spring 2017 Member of Cal Poly, Team S13-G1, Forte Spring 2017
CPSU-FORTE-S17S13G1
4 Members
5 Guides authored
One Comment
I whant purchase capacitor 330
35v
Chandan Kumar - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 20
All Time: 3,819
