Bose SoundTouch Portable Speaker Replacement
  1. Bose SoundTouch Portable Speaker Replacement, Speaker Battery: step 1, image 1 of 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Speaker Replacement: step 2, image 1 of 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Speaker Replacement: step 3, image 1 of 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Speaker Replacement, Grille: step 4, image 1 of 1
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Speaker Replacement: step 5, image 1 of 1
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Speaker Replacement: step 6, image 1 of 1
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Speaker Replacement, Speakers: step 7, image 1 of 1
    • There are four T-10 Torx screws for each speaker; remove all four screws for each speaker you are replacing.
  8. Bose SoundTouch Portable Speaker Replacement: step 8, image 1 of 3 Bose SoundTouch Portable Speaker Replacement: step 8, image 2 of 3 Bose SoundTouch Portable Speaker Replacement: step 8, image 3 of 3
    • Using a plastic pry tool, carefully pry the speaker up.
    • With the bottom of the speaker exposed, unwind the wires from the connection tabs and replace the speaker.
Chelsea Martin
703 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Leahy Spring 2017 Member of USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 15
All Time: 1,921
