Bose SoundTouch Portable Subwoofer Replacement
  1. Bose SoundTouch Portable Subwoofer Replacement, Speaker Battery: step 1, image 1 of 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Subwoofer Replacement: step 2, image 1 of 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Subwoofer Replacement: step 3, image 1 of 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Subwoofer Replacement, Grille: step 4, image 1 of 1
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Subwoofer Replacement: step 5, image 1 of 1
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Subwoofer Replacement: step 6, image 1 of 1
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Subwoofer Replacement, Metal Trim: step 7, image 1 of 1
    • Remove the two screws using a torx screwdriver.
  8. Bose SoundTouch Portable Subwoofer Replacement: step 8, image 1 of 1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  9. Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: step 9, image 1 of 2 Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: step 9, image 2 of 2
    • Separate the case that holds the subwoofer in place.
    • Be careful when doing this step because there are several connectors inside.
  10. Bose SoundTouch Portable Subwoofer Replacement: step 10, image 1 of 1
    • Gently pull on the connectors at the circuit board to remove. Remove the screws from the circuit board and set the board aside.
  11. Bose SoundTouch Portable Subwoofer Replacement: step 11, image 1 of 3 Bose SoundTouch Portable Subwoofer Replacement: step 11, image 2 of 3 Bose SoundTouch Portable Subwoofer Replacement: step 11, image 3 of 3
    • Remove the four screws from the subwoofer and lift it out of the casing.
Chelsea Martin
703 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Leahy Spring 2017 Member of USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Members
11 Guides authored
2 Guide Comments
Thanks a lot for sharing your incredible ideas. It is an appreciated and pretty tip for all those music lovers. What a Fatal post for those who want to upgrade an existing subwoofer with a new one.
About more: www.outdoorsumo.com
Outdoor Sumo - Reply
About more: ++https://compactcarsubwoofer.blogspot.com...
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 26
All Time: 1,666
