Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement
  1. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, Speaker Battery: step 1, image 1 of 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement: step 2, image 1 of 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement: step 3, image 1 of 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, Metal Trim: step 4, image 1 of 1
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement: step 5, image 1 of 1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, USB/AC Adapter and AUX Cord: step 6, image 1 of 3 Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, USB/AC Adapter and AUX Cord: step 6, image 2 of 3 Bose SoundTouch Portable USB/AC Adapter and Aux Cord Replacement, USB/AC Adapter and AUX Cord: step 6, image 3 of 3
    • Remove the two T-10 Torx screws
    • Remove the black casing
    • Pry off flat connector
2 other people completed this guide.
Chelsea Martin
697 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Leahy Spring 2017 Member of USF Tampa, Team S1-G3, Leahy Spring 2017
USFT-LEAHY-S17S1G3
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,656
