Bose Soundlink Flex Driver Replacement
  1. Bose Soundlink Flex Driver Replacement, Grille: step 1, image 1 of 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Driver Replacement: step 2, image 1 of 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Driver Replacement: step 3, image 1 of 2 Bose Soundlink Flex Driver Replacement: step 3, image 2 of 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
  4. Bose Soundlink Flex Driver Replacement, Driver: step 4, image 1 of 3 Bose Soundlink Flex Driver Replacement, Driver: step 4, image 2 of 3 Bose Soundlink Flex Driver Replacement, Driver: step 4, image 3 of 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
  5. Bose Soundlink Flex Driver Replacement: step 5, image 1 of 3 Bose Soundlink Flex Driver Replacement: step 5, image 2 of 3 Bose Soundlink Flex Driver Replacement: step 5, image 3 of 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
  6. Bose Soundlink Flex Driver Replacement: step 6, image 1 of 2 Bose Soundlink Flex Driver Replacement: step 6, image 2 of 2
    • Desolder the joints that are connecting the speaker to the motherboard.
    • Solder the new speaker with the wire color in the same order.
    • Be cautious when removing and adding the solder to not damage the motherboard or burn yourself.
Kalvin Lee
579 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 82
All Time: 1,156
