Bose Soundlink Flex Grille Replacement
  1. Bose Soundlink Flex Grille Replacement, Grille: step 1, image 1 of 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Grille Replacement: step 2, image 1 of 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Grille Replacement: step 3, image 1 of 2 Bose Soundlink Flex Grille Replacement: step 3, image 2 of 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
Isaac
223 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 48
All Time: 571
