Bose Soundlink Flex Radiator Replacement
  1. Bose Soundlink Flex Radiator Replacement, Grille: step 1, image 1 of 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Radiator Replacement: step 2, image 1 of 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Radiator Replacement: step 3, image 1 of 2 Bose Soundlink Flex Radiator Replacement: step 3, image 2 of 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
  4. Bose Soundlink Flex Radiator Replacement, Radiator: step 4, image 1 of 3 Bose Soundlink Flex Radiator Replacement, Radiator: step 4, image 2 of 3 Bose Soundlink Flex Radiator Replacement, Radiator: step 4, image 3 of 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
  5. Bose Soundlink Flex Radiator Replacement: step 5, image 1 of 2 Bose Soundlink Flex Radiator Replacement: step 5, image 2 of 2
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
  6. Bose Soundlink Flex Radiator Replacement: step 6, image 1 of 3 Bose Soundlink Flex Radiator Replacement: step 6, image 2 of 3 Bose Soundlink Flex Radiator Replacement: step 6, image 3 of 3
    • Pull the backplate off to expose both sides of the radiator.
  7. Bose Soundlink Flex Radiator Replacement: step 7, image 1 of 3 Bose Soundlink Flex Radiator Replacement: step 7, image 2 of 3 Bose Soundlink Flex Radiator Replacement: step 7, image 3 of 3
    • Remove the four 2.3 mm corner screws using a TR8 Torx screwdriver.
    • Remove the two 1.7 mm screws using a TR6 Torx screwdriver.
    • Follow this step for both radiators.
  8. Bose Soundlink Flex Radiator Replacement: step 8, image 1 of 2 Bose Soundlink Flex Radiator Replacement: step 8, image 2 of 2
    • Remove the radiator and replace with the new radiator.
Monica Silva
235 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 54
All Time: 663
