Bose Soundlink II Battery Replacement
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: step 1, image 1 of 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: step 2, image 1 of 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: step 3, image 1 of 1
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: step 4, image 1 of 2 Bose Soundlink II Battery Replacement: step 4, image 2 of 2
    • Carefully remove the battery by pulling it out of the speaker.
17 other people completed this guide.
Kevin Bailey
500 Reputation
2 Guides authored
Texas Tech, Team 22-4, Rauch Fall 2015 Member of Texas Tech, Team 22-4, Rauch Fall 2015
TTU-RAUCH-F15S22G4
3 Members
5 Guides authored
11 Guide Comments
Where i can buy one them battery model?
Daniel Campos - Reply
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - Reply
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - Reply
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - Reply
How much the battery only
Joboy De Guzman II - Reply
Past 24 Hours: 7
Past 7 Days: 54
Past 30 Days: 289
All Time: 36,699
