Bose Soundlink III Battery Replacement
  1. Bose Soundlink III Battery Replacement, Battery: step 1, image 1 of 1
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose Soundlink III Battery Replacement: step 2, image 1 of 2 Bose Soundlink III Battery Replacement: step 2, image 2 of 2
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose Soundlink III Battery Replacement: step 3, image 1 of 1
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose Soundlink III Battery Replacement: step 4, image 1 of 2 Bose Soundlink III Battery Replacement: step 4, image 2 of 2
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
39 other people completed this guide.
Dakoda Sanders
1,558 Reputation
4 Guides authored
USF Tampa, Team 3-2, Wollert Spring 2016 Member of USF Tampa, Team 3-2, Wollert Spring 2016
USFT-WOLLERT-S16S3G2
4 Members
8 Guides authored
26 Comments
Hello, I wonder where I could buy a raplacement battery for my Bose Soundlink III. (I'm from Belgium)
Thanks for the response.
Gabriel Lohest - Reply
Gabriel, ik heb Bose gecontacteerd en ze zeggen dat ze dat niet apart verkopen. Het enigste wat ik heb gevonden is dit:http://www.ecrater.com/p/25268626/batter...
Of als het nog onder garantie valt, gewoon terug opsturen.
Gabrial, I've contacted Bose and they say that they didn't sell them seperately. The only thing that I've found is this:http://www.ecrater.com/p/25268626/batter...
If it still falls under warranty, send the speaker back.
JJ Hu - Reply
yea i'm also interested to buy bose soundlink 3 battery hurmmm where could i get it....
Admin Fluffy - Reply
Yes please, where do you get replacement batteries (I'm from Australia and Bose here want to charge me $149 to remove and replace 4 screws!)
Bob Mandassa - Reply
I want to buy also. I'm here in Saudi arabia dammam
alphamendoza5 - Reply
Past 24 Hours: 15
Past 7 Days: 110
Past 30 Days: 435
All Time: 62,927
