Bose Soundlink Mini II Speaker Guard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Bose Soundlink Mini II Speaker Guard Replacement, Speaker Guard: step 1, image 1 of 2 Bose Soundlink Mini II Speaker Guard Replacement, Speaker Guard: step 1, image 2 of 2
    • Two mesh tabs hold the speaker guard in place on either end.
    • Use the plastic opening tool to peel away the rubber insert.
    • Use the metal spudger to lift one of the tabs away from the device.
  2. Bose Soundlink Mini II Speaker Guard Replacement: step 2, image 1 of 2 Bose Soundlink Mini II Speaker Guard Replacement: step 2, image 2 of 2
    • Carefully peel the mesh speaker guard away from the device.
  3. Bose Soundlink Mini II Speaker Guard Replacement: step 3, image 1 of 1
    • Remove the mesh tabs from the other side of the device.
  4. Bose Soundlink Mini II Speaker Guard Replacement: step 4, image 1 of 2 Bose Soundlink Mini II Speaker Guard Replacement: step 4, image 2 of 2
    • To replace the speaker guard, make sure the rubber insert is in place on the back of the mesh guard.
    • Insert one end of the speaker guard into the frame. Then gently fit the other end of the speaker guard into the frame.
    • You will have to fit the tabs on one end into the device first, and then slightly bend the guard into the other side.
    • Press firmly on the speaker guard ensuring that it is properly installed.
Finish Line
7 other people completed this guide.
Jackie Dupuis
239 Reputation
1 Guide authored
Texas Tech, Team 19-2, Rauch Fall 2015 Member of Texas Tech, Team 19-2, Rauch Fall 2015
TTU-RAUCH-F15S19G2
5 Members
1 Guide authored
4 Comments
Where do you buy the replacement speaker guards from? (UK)
markfrances9 - Reply
Where do you find a spare speaker guard for the soundlink mini 2?
My mail. "engadin@gmx.ch" regards Peter
Peter Bacher - Reply
Where do I find a speaker guard for soundlink mini 2 please. Regards Peter
i have a bose soundlink mini 2, oneday i left it on and left my room. on my return i found out that it has gone off and since then it cannot turn on again. i have charged it overnight, in fact i have charged it for both short and long time but still can't turn on. when i press the power button it doesn't show any sign of booting.
can you repair my bose soundlink mini 2 for me?
king fazz - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,901
