Bose Soundlink Revolve AUX/USB Port Replacement
  1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: step 1, image 1 of 2 Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: step 1, image 2 of 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve AUX/USB Port Replacement: step 2, image 1 of 3 Bose Soundlink Revolve AUX/USB Port Replacement: step 2, image 2 of 3 Bose Soundlink Revolve AUX/USB Port Replacement: step 2, image 3 of 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve AUX/USB Port Replacement: step 3, image 1 of 2 Bose Soundlink Revolve AUX/USB Port Replacement: step 3, image 2 of 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve AUX/USB Port Replacement: step 4, image 1 of 2 Bose Soundlink Revolve AUX/USB Port Replacement: step 4, image 2 of 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: step 5, image 1 of 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: step 5, image 2 of 3 Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: step 5, image 3 of 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
14 other people completed this guide.
Brian Butner
861 Reputation
3 Guides authored
USF Tampa, Team S6-G2, Remmell Fall 2017 Member of USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 Members
4 Guides authored
17 Comments
Any idea where I can find the USB/Aux board for sale?
Chad - Reply
Did you ever manage to find a place to buy it?
Steve Fantin -
You can buy a charging cradle for this device, maybe that helps..
adsf -
I am also looking for the usb port replacement part.
James Nowicki - Reply
Past 24 Hours: 10
Past 7 Days: 69
Past 30 Days: 333
All Time: 31,909
