Introduction
Use this guide to replace the bottom motherboard of your device.
Flip speaker over so that the bottom is facing up.
Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
Remove the AUX/USB port from the device.
Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
Remove the motherboard from the device.
6 other people completed this guide.
42 Comments
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
