Bose Wave Radio AWR1-1W Speaker Replacement
  1. Bose Wave Radio AWR1-1W Speaker Replacement, Base: step 1, image 1 of 2 Bose Wave Radio AWR1-1W Speaker Replacement, Base: step 1, image 2 of 2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Speaker Replacement: step 2, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 2, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 2, image 3 of 3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Speaker Replacement: step 3, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 3, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 3, image 3 of 3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Speaker Replacement: step 4, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 4, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 4, image 3 of 3
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Speaker Replacement: step 5, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 5, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 5, image 3 of 3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Speaker Replacement: step 6, image 1 of 1
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: step 7, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: step 7, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: step 7, image 3 of 3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Speaker Replacement: step 8, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 8, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 8, image 3 of 3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Speaker Replacement: step 9, image 1 of 1
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: step 10, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: step 10, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: step 10, image 3 of 3
    • Remove a total of eight 15mm Phillips #2 screws surrounding each speaker.
  11. Bose Wave Radio AWR1-1W Speaker Replacement: step 11, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 11, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 11, image 3 of 3
    • Gently pull each speaker out of the device.
  12. Bose Wave Radio AWR1-1W Speaker Replacement: step 12, image 1 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 12, image 2 of 3 Bose Wave Radio AWR1-1W Speaker Replacement: step 12, image 3 of 3
    • Pull the wire connected to the speakers out of the device.
    • You already disconnected this wire from the inside of the device earlier.
6 other people completed this guide.
Cassie Harriman
1,033 Reputation
5 Guides authored
Cal Poly, Team S15-G2, Banghart Spring 2017 Member of Cal Poly, Team S15-G2, Banghart Spring 2017
CPSU-BANGHART-S17S15G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 46
All Time: 7,058
