Bose-301 Series II Tweeter Replacement
  1. Bose-301 Series II Tweeter Replacement, Tweeter: step 1, image 1 of 3 Bose-301 Series II Tweeter Replacement, Tweeter: step 1, image 2 of 3 Bose-301 Series II Tweeter Replacement, Tweeter: step 1, image 3 of 3
    • Begin the repair by placing the Bose-301 speaker vertically.
    • Using two hands, pull the speaker grill towards you and away from the speaker body.
  2. Bose-301 Series II Tweeter Replacement: step 2, image 1 of 1
    • Pull the main speaker grill towards you to remove it from the body structure.
  3. Bose-301 Series II Tweeter Replacement: step 3, image 1 of 3 Bose-301 Series II Tweeter Replacement: step 3, image 2 of 3 Bose-301 Series II Tweeter Replacement: step 3, image 3 of 3
    • Lay the speaker body on its back.
    • Using the Philips Screwdriver, carefully remove the four #2x19mm screws that mount the main speaker to the speaker body.
  4. Bose-301 Series II Tweeter Replacement: step 4, image 1 of 2 Bose-301 Series II Tweeter Replacement: step 4, image 2 of 2
    • Untwist the slack in the wires that are connected to the main speaker.
  5. Bose-301 Series II Tweeter Replacement: step 5, image 1 of 3 Bose-301 Series II Tweeter Replacement: step 5, image 2 of 3 Bose-301 Series II Tweeter Replacement: step 5, image 3 of 3
    • Carefully place the speaker off to the side.
    • Be sure to not place the speaker face down or put pressure on the speaker cone as this can damage the cone.
    • Be aware of the very strong magnet in the driver of the speaker, which can cause damage to electronic devices in close proximity.
    • Then untwist the slack in the wires that are connected to the tweeters.
  6. Bose-301 Series II Tweeter Replacement: step 6, image 1 of 1
    • Using the socket wrench and the 1/4" socket, unscrew the 12.5 mm bolt that mounts the tweeter to the bracket.
  7. Bose-301 Series II Tweeter Replacement: step 7, image 1 of 1
    • While holding the tweeter, use your other hand to feed the wire through the hole at the bottom of the tweeter mount.
  8. Bose-301 Series II Tweeter Replacement: step 8, image 1 of 2 Bose-301 Series II Tweeter Replacement: step 8, image 2 of 2
    • Remove the tweeter from the mount and locate the two wires that connect it to the speaker.
    • Using the pliers, untwist the wires that are attached to the two small rods at the bottom of the tweeter.
    • Repeat process for the second tweeter.
    • Be sure not to excessively bend the bare wires in order to reuse it for the replacement tweeters.
To reassemble your speaker, follow these instructions in reverse order.
3 other people completed this guide.
Patrick Emery
174 Reputation
1 Guide authored
USF Tampa, Team 15-3, Remmell Spring 2017 Member of USF Tampa, Team 15-3, Remmell Spring 2017
USFT-REMMELL-S17S15G3
4 Members
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 39
All Time: 7,248
