Braun 5514 Battery Replacement
Andrew Kluckhuhn
Andrew Kluckhuhn and 2 other contributors
Last updated on January 23, 2025
30 - 45 minutes
Moderate
Introduction
Go to step 1
Over time, rechargeable batteries lose their ability to recharge. This guide shows you how to replace the battery in a Braun trimmer.
Tools
Show more…
  1. Braun 5514 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove any attached trimmer heads by gripping and pulling away from the body.
  2. Braun 5514 Battery Replacement: step 2, image 1 of 3 Braun 5514 Battery Replacement: step 2, image 2 of 3 Braun 5514 Battery Replacement: step 2, image 3 of 3
    • Insert an opening pick between the top plate and the grey separator.
    • Slide the opening pick around the perimeter of the plate to release the hidden clips.
  3. Braun 5514 Battery Replacement: step 3, image 1 of 1
    • Remove the four 7.0mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
  4. Braun 5514 Battery Replacement: step 4, image 1 of 2 Braun 5514 Battery Replacement: step 4, image 2 of 2
    • Use the opening pick to lift the grey frame from the black casing.
  5. Braun 5514 Battery Replacement: step 5, image 1 of 2 Braun 5514 Battery Replacement: step 5, image 2 of 2
    • Remove the circuit board assembly from the frame.
  6. Braun 5514 Battery Replacement: step 6, image 1 of 1
    • Pull the small black plastic piece out of the frame.
  7. Braun 5514 Battery Replacement: step 7, image 1 of 2 Braun 5514 Battery Replacement: step 7, image 2 of 2
    • Desolder the four tabs connecting the batteries to the circuit board.
    • Repeat for the other side of the battery.
27 other people completed this guide.
Andrew Kluckhuhn
1,079 Reputation
2 Guides authored
IUPUI, Team S2-G2, Harley Summer 2018 Member of IUPUI, Team S2-G2, Harley Summer 2018
IUPUI-HARLEY-SU18S2G2
4 Members
8 Guides authored
12 Comments
What is the name/part nr. of the battery?
Casper Smit - Reply
Thanks!
This manual is applicable for the model 5516, too :-)
The battery type should be: AAA 1000 mAh; make sure, to choose batteries, that are prepared for soldering!!
Lucas B - Reply
Same goes for 5515.
Thanks for the guide :)
Yordan Chanev - Reply
Thanks, I was looking how to take apart 5513, similar enough, as far as the battery replacement goes, any rechargeable AAA battery should do. Batteries don’t like the heat from soldering iron, there are kits for welding batteries, another idea is to get cheap battery holder if you can fit it in.
Mariusz Lewicki - Reply
Does the 1.2V Ni-MH AAA 1000mAh battery work, have an older model MGK5280 ?
Thanks.
Jhon Jones - Reply
Past 24 Hours: 23
Past 7 Days: 214
Past 30 Days: 662
All Time: 47,200
