Braun 5514 Motor Replacement
  1. Braun 5514 Motor Replacement, Motor: step 1, image 1 of 1
    • Remove any attached trimmer heads by gripping and pulling away from the body.
  2. Braun 5514 Motor Replacement: step 2, image 1 of 3 Braun 5514 Motor Replacement: step 2, image 2 of 3 Braun 5514 Motor Replacement: step 2, image 3 of 3
    • Insert an opening pick between the top plate and the grey separator.
    • Slide the opening pick around the perimeter of the plate to release the hidden clips.
  3. Braun 5514 Motor Replacement: step 3, image 1 of 1
    • Remove the four 7mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
  4. Braun 5514 Motor Replacement: step 4, image 1 of 2 Braun 5514 Motor Replacement: step 4, image 2 of 2
    • Use the opening pick to lift the grey frame from the black casing.
  5. Braun 5514 Motor Replacement: step 5, image 1 of 2 Braun 5514 Motor Replacement: step 5, image 2 of 2
    • Remove the circuit board assembly from the frame.
  6. Braun 5514 Motor Replacement: step 6, image 1 of 1
    • Pull the small black plastic piece out of the frame.
  7. Braun 5514 Motor Replacement: step 7, image 1 of 2 Braun 5514 Motor Replacement: step 7, image 2 of 2
    • Desolder the wires attached to the motor.
    • Remember where the red and black wires attach in case the replacement motor doesn't have it labeled.
3 other people completed this guide.
Andrew Kluckhuhn
1,079 Reputation
2 Guides authored
IUPUI, Team S2-G2, Harley Summer 2018 Member of IUPUI, Team S2-G2, Harley Summer 2018
IUPUI-HARLEY-SU18S2G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 30
Past 30 Days: 60
All Time: 3,560
