Braun Series 7 790cc-7 Battery Replacement
  1. Braun Series 7 790cc-7 Battery Replacement, Battery: step 1, image 1 of 2 Braun Series 7 790cc-7 Battery Replacement, Battery: step 1, image 2 of 2
    • Use a spudger to remove the rubber piece on the back of the razor.
  2. Braun Series 7 790cc-7 Battery Replacement: step 2, image 1 of 1
    • Use a Torx T8 to remove (4) 10 mm screws from housing.
  3. Braun Series 7 790cc-7 Battery Replacement: step 3, image 1 of 2 Braun Series 7 790cc-7 Battery Replacement: step 3, image 2 of 2
    • Remove the rear cover from the device.
  4. Braun Series 7 790cc-7 Battery Replacement: step 4, image 1 of 1
    • Remove the battery from the holster inside the device.
  5. Braun Series 7 790cc-7 Battery Replacement: step 5, image 1 of 1
    • Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
    • Be sure to insert the battery the correct way.
27 other people completed this guide.
Alex Speer
763 Reputation
1 Guide authored
IUPUI, Team S3-G6, Harley Fall 2017 Member of IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
3 Members
5 Guides authored
27 Comments
Where do you buy the Battery?
bruce Forsyth - Reply
Any idea on how to remove/replace the drive unit? I bought a new one but the plastic backing is extremely hard to get off.
Chris - Reply
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
arcticassault - Reply
How do you reset the battery life indicator on the shaver after replacement?
jclemis - Reply
Past 24 Hours: 30
Past 7 Days: 161
Past 30 Days: 706
All Time: 54,671
