Braun Series 7 790cc-7 Charging Base Wire Harness Replacement
  1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement, Charging base wire harness: step 1, image 1 of 1
    • Remove the cleaner cartridge from the charging base.
  2. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 2, image 1 of 3 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 2, image 2 of 3 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 2, image 3 of 3
    • Depress the 4 tabs while lightly pulling the cover from the base.
    • Next, depress the 2 molded tabs while still pulling the cover from the base.
  3. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 3, image 1 of 1
    • Press inward on the side charging port while pulling cover from the base to separate.
  4. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 4, image 1 of 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 4, image 2 of 2
    • Remove side charging port by prying tabs outward and rotating port upward.
  5. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 5, image 1 of 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 5, image 2 of 2
    • Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
  6. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 6, image 1 of 2 Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: step 6, image 2 of 2
    • Remove solder from circuit board and remove charging harness.
Ian Hayes
216 Reputation
2 Guides authored
IUPUI, Team S3-G6, Harley Fall 2017 Member of IUPUI, Team S3-G6, Harley Fall 2017
IUPUI-HARLEY-F17S3G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 18
All Time: 1,100
