Braun multipractic K 3000 Replacing the driver on the universal bowl
  1. Braun multipractic K 3000 Replacing the driver on the universal bowl, K 3000 driver on the universal bowl: step 1, image 1 of 2 Braun multipractic K 3000 Replacing the driver on the universal bowl, K 3000 driver on the universal bowl: step 1, image 2 of 2
    • Turn the universal bowl over so that the base is facing upwards.
    • The crack in the driver is clearly visible. The driver is therefore slipping in the bowl.
  2. Braun multipractic K 3000 Replacing the driver on the universal bowl: step 2, image 1 of 1
    • Carefully lift the driver off the axle using a strong flat-blade screwdriver. Reposition it several times so that it does not jam.
  3. Braun multipractic K 3000 Replacing the driver on the universal bowl: step 3, image 1 of 2 Braun multipractic K 3000 Replacing the driver on the universal bowl: step 3, image 2 of 2
    • Here you can see the axle and the driver.
    • Create a new driver with the 3D printer. Print out the two press-fit tools at the same time.
    • Lightly grease the axle with food-safe silicone grease and push it in.
    • Insert translation here
    • Pay attention to the washers: first the smaller metal washer at the top, then the slightly larger plastic washer. At the bottom, only the metal washer rests on the driver
    • Fit the new driver.
    • Place the two press-fit tools (or a suitable piece of wood) on the top and bottom and press the driver tight with a screw clamp.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
210,196 Reputation
255 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
26 Members
1,185 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 235
