Braven BRV-1M Outer Casing Replacement
  1. Braven BRV-1M Outer Casing Replacement, Outer Casing: step 1, image 1 of 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Outer Casing Replacement: step 2, image 1 of 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Outer Casing Replacement: step 3, image 1 of 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Outer Casing Replacement: step 4, image 1 of 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
Erik Oliva
607 Reputation
6 Guides authored
USF Tampa, Team S2-G1, Eyestone Spring 2018 Member of USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Members
6 Guides authored
One Comment
Where can I buy parts for this speaker? My rear charging door has broken off disabling the ruggedness. Be easier to buy versus build new piece.
Michael Harruff - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 635
