Braven BRV-1M Sub-woofer Cone Replacement
  1. Braven BRV-1M Sub-woofer Cone Replacement, Sub-woofer Cone: step 1, image 1 of 1
    • To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
  2. Braven BRV-1M Sub-woofer Cone Replacement: step 2, image 1 of 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Sub-woofer Cone Replacement: step 3, image 1 of 1
    • To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
  4. Braven BRV-1M Sub-woofer Cone Replacement: step 4, image 1 of 1
    • Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
Erik Oliva
607 Reputation
6 Guides authored
USF Tampa, Team S2-G1, Eyestone Spring 2018 Member of USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 189
