Braven BRV-1s Speaker Cone Replacement
  1. Braven BRV-1s Speaker Cone Replacement, Outer Casing: step 1, image 1 of 1
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
  2. Braven BRV-1s Speaker Cone Replacement: step 2, image 1 of 1
    • Using a metal spudger, gently pry the side of the defective case.
  3. Braven BRV-1s Speaker Cone Replacement: step 3, image 1 of 1
    • Still using the metal spudger, continue to work your way around the outer case.
  4. Braven BRV-1s Speaker Cone Replacement: step 4, image 1 of 1
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
  5. Braven BRV-1s Speaker Cone Replacement, Speaker Cone: step 5, image 1 of 1
    • To remove the speaker cone plate, remove 10 phillips screws (Phillips #00 headtype, 9.3mm long)
  6. Braven BRV-1s Speaker Cone Replacement: step 6, image 1 of 1
    • Using a metal spudger, gently pry the side of the defective speaker cone plate.
    • Remember to pry all around the side of the speaker cone plate.
    • Keep in mind that the adhesive will make it difficult to pry the plate off. To loosen the adhesive, heat the plate with a device such as a hair dryer.
  7. Braven BRV-1s Speaker Cone Replacement: step 7, image 1 of 2 Braven BRV-1s Speaker Cone Replacement: step 7, image 2 of 2
    • Remove the broken speaker cone plate. Replace with used/new out plate.
Leanne Abel
101 Reputation
1 Guide authored
IUPUI, Team S2-G2, Harley Spring 2017 Member of IUPUI, Team S2-G2, Harley Spring 2017
IUPUI-HARLEY-S17S2G2
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 741
