Braven BRV-X Front Speaker Panel Replacement
  1. Braven BRV-X Front Speaker Panel Replacement, Front Speaker Panel: step 1, image 1 of 1
    • Remove four 1.1 cm outer screws in the outer shell using the Phillips #00 screwdriver.
  2. Braven BRV-X Front Speaker Panel Replacement: step 2, image 1 of 1
    • Remove four 1.3 cm inner screws in the outer shell using the 1.5mm Hex screwdriver.
  3. Braven BRV-X Front Speaker Panel Replacement: step 3, image 1 of 1
    • Gently remove the outer shell.
  4. Braven BRV-X Front Speaker Panel Replacement: step 4, image 1 of 2 Braven BRV-X Front Speaker Panel Replacement: step 4, image 2 of 2
    • Cut adhesive tape on both sides.
  5. Braven BRV-X Front Speaker Panel Replacement: step 5, image 1 of 2 Braven BRV-X Front Speaker Panel Replacement: step 5, image 2 of 2
    • Remove eighteen 0.9cm screws in the inner shell using the Phillips #00 screwdriver.
  6. Braven BRV-X Front Speaker Panel Replacement: step 6, image 1 of 3 Braven BRV-X Front Speaker Panel Replacement: step 6, image 2 of 3 Braven BRV-X Front Speaker Panel Replacement: step 6, image 3 of 3
    • Pry open the glued inner shell using a spudger around all sides of the shell.
    • Don't use too much pressure as that could cause damage to the plastic.
  7. Braven BRV-X Front Speaker Panel Replacement: step 7, image 1 of 2 Braven BRV-X Front Speaker Panel Replacement: step 7, image 2 of 2
    • Remove ten 0.7 cm screws in the front plate using the 1.5 mm Hex screwdriver.
  8. Braven BRV-X Front Speaker Panel Replacement: step 8, image 1 of 2 Braven BRV-X Front Speaker Panel Replacement: step 8, image 2 of 2
    • Use a spudger to open the front speaker plate.
  9. Braven BRV-X Front Speaker Panel Replacement: step 9, image 1 of 1
    • Remove three 1.0 cm screws from the battery unit.
    • It is recommended (but not required) to remove the battery.
  10. Braven BRV-X Front Speaker Panel Replacement: step 10, image 1 of 2 Braven BRV-X Front Speaker Panel Replacement: step 10, image 2 of 2
    • Disconnect the ribbon cable attached the main board.
  11. Braven BRV-X Front Speaker Panel Replacement: step 11, image 1 of 3 Braven BRV-X Front Speaker Panel Replacement: step 11, image 2 of 3 Braven BRV-X Front Speaker Panel Replacement: step 11, image 3 of 3
    • Pry open the second plate holding in the speaker using a spudger around all sides.
    • It is recommended to use a spudger to remove the heavily glued areas between the plates before prying.
  12. Braven BRV-X Front Speaker Panel Replacement: step 12, image 1 of 3 Braven BRV-X Front Speaker Panel Replacement: step 12, image 2 of 3 Braven BRV-X Front Speaker Panel Replacement: step 12, image 3 of 3
    • Cut the 20 gauge wires attached to the front IR sensor and two speaker wires.
    • Leave enough length on the wire to work with it afterwards.
    • Cut the 22 gauge wire attached in the corner.
    • Solder the new speaker plate during reassembly.
    • To properly solder and desolder connections, visit the How to Solder and Desolder Connections guide.
Trey Peterson
301 Reputation
2 Guides authored
IUPUI, Team S1-G5, Harley Spring 2019 Member of IUPUI, Team S1-G5, Harley Spring 2019
IUPUI-HARLEY-S19S1G5
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 268
