Breville JE98XL Juice Fountain Plus Filter Basket Replacement
  1. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Pulp Basket: step 1, image 1 of 1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 2, image 1 of 1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 3, image 1 of 1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Lid: step 4, image 1 of 2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Lid: step 4, image 2 of 2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 5, image 1 of 2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 5, image 2 of 2
    • Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
  6. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Filter Basket: step 6, image 1 of 2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Filter Basket: step 6, image 2 of 2
    • Twist the filter bowl that surrounds the basket in a counterclockwise fashion. Lift the bowl straight up to remove it from the juicer.
  7. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 7, image 1 of 3 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 7, image 2 of 3 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 7, image 3 of 3
    • To remove the filter basket from the surrounding bowl, use a plastic opening tool to create separation between the basket and the bowl.
    • Once there is enough room, place your fingers under the grooves of the filter basket and lift up.
  8. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 8, image 1 of 2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 8, image 2 of 2
    • In order to access the cutting disc, the basket must be removed from the base. To do this, simply lift the basket up and off of the base.
  9. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 9, image 1 of 2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 9, image 2 of 2
    • To remove the cutting disc, unscrew the three Phillips #1 screws.
  10. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: step 10, image 1 of 1
    • With all three screws removed, use a plastic opening tool to lift the cutting disc out of the filter basket.
    • The cutting disc has many small and sharp blades. Make sure to hold the disc in between blades when handling.
Madison Burgess
499 Reputation
3 Guides authored
Cal Poly, Team 15-1, Livingston Fall 2016 Member of Cal Poly, Team 15-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G1
3 Members
4 Guides authored
2 Comments
What are the 3 exact screws for this part? Lost one of the screws when taking apart.
Adam Samsonov - Reply
I Twist the filter bowl that surrounds the basket in a counterclockwise fashion. And try Lifting the bowl straight up to remove it from the juicer, but it will not seperate any suggestions?
Robert morris - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,693
