Briggs and Stratton 675 Series Repair Pull Cord Replacement
  1. Briggs and Stratton 675 Series Repair Pull Cord Replacement, Pull Cord: step 1, image 1 of 1
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before begining.
    • Use a Phillips #2 screwdriver to remove the two 25mm screws on top of the engine cover.
  2. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 2, image 1 of 2 Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 2, image 2 of 2
    • Use your hands to lift the engine cover off, separating it from the rest of the engine.
    • Slip the pull cord through the engine top cover after separating it.
  3. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 3, image 1 of 2 Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 3, image 2 of 2
    • Use a socket wrench with a 5/16" socket to remove the three 17mm screws that keep the fuel tank attached.
    • Tilt the fuel tank back at least 45 degrees to get it out of your way.
  4. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 4, image 1 of 2 Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 4, image 2 of 2
    • Use a socket wrench with a 3/8" socket to remove the two 26mm screws at the back of the engine shield.
    • Use a socket wrench with a 5/16" socket to remove the 17mm screw on the top of the engine shield.
  5. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 5, image 1 of 2 Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 5, image 2 of 2
    • Remove the oil funnel from the rest of the engine. It should pull away easily and come off completely.
    • Make sure there isn't an overflow of oil in the funnel or hose before removing it to avoid spilling.
  6. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 6, image 1 of 1
    • Use a socket wrench with a 3/8" socket to remove the two 20mm screws on the front of the engine shield.
  7. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 7, image 1 of 1
    • Remove the engine shield and flip it over.
  8. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 8, image 1 of 2 Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 8, image 2 of 2
    • If you are missing a pull cord, skip straight to step 9.
    • Pull the cord back until it is completely unwound from the starter mechanism spool.
    • Wedge a screwdriver into the gap to hold the spool in place.
    • Cut the end of the pull cord with scissors or a knife.
  9. Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 9, image 1 of 2 Briggs and Stratton 675 Series Repair Pull Cord Replacement: step 9, image 2 of 2
    • Line up the hole on the outside of the engine shield with the hole on the inside, then slip the new pull cord through and tie a knot.
4 other people completed this guide.
Andrew Saunders
957 Reputation
2 Guides authored
Cal Poly, Team 6-31, Amido Winter 2015 Member of Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Members
15 Guides authored
12 Comments
Thanks alot for this guide. I was able to get the pull cord fixed without hassle at all. When I saw my string about to break I knew I was about to blow a bunch of money to have it fixed. Thanks again!
howellgerald - Reply
Anyone know how to fix a carb fire
Cody Nitardy - Reply
took me right through to the part where the cord is run but not wound and pretensioned ready for start, now what?
Duncan Laurie - Reply
Go back to step 8, where it says to pull the cord out and wedge a screwdriver in the spool to hold it under tension. If you have no cord on the spool, you'll have to rotate it to put the spool under tension, then wedge a screwdriver in to hold it, insert the new cord, tie the knot, then remove the screwdriver to release the tension, so the spool will wind the cord up.
chris04528 -
Spring unwind how to replace it
Bobby - Reply
Past 24 Hours: 9
Past 7 Days: 78
Past 30 Days: 321
All Time: 48,499
