Briggs and Stratton 675 Series Spark Plug Replacement
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: step 1, image 1 of 2 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: step 1, image 2 of 2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: step 2, image 1 of 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: step 2, image 2 of 3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: step 2, image 3 of 3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
6 other people completed this guide.
Andrew Saunders
957 Reputation
2 Guides authored
Cal Poly, Team 6-31, Amido Winter 2015 Member of Cal Poly, Team 6-31, Amido Winter 2015
CPSU-AMIDO-W15S6G31
4 Members
15 Guides authored
12 Comments
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Reply
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Reply
pinch the front of black cap and pull off
tracy.mullen - Reply
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Reply
Kymberleah - Reply
Past 24 Hours: 11
Past 7 Days: 69
Past 30 Days: 370
All Time: 48,086
