Brightsign 4k Battery Replacement
  1. Brightsign 4k Battery Replacement, Outer Shell: step 1, image 1 of 3 Brightsign 4k Battery Replacement, Outer Shell: step 1, image 2 of 3 Brightsign 4k Battery Replacement, Outer Shell: step 1, image 3 of 3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Battery Replacement: step 2, image 1 of 3 Brightsign 4k Battery Replacement: step 2, image 2 of 3 Brightsign 4k Battery Replacement: step 2, image 3 of 3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Battery Replacement: step 3, image 1 of 3 Brightsign 4k Battery Replacement: step 3, image 2 of 3 Brightsign 4k Battery Replacement: step 3, image 3 of 3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Battery Replacement: step 4, image 1 of 3 Brightsign 4k Battery Replacement: step 4, image 2 of 3 Brightsign 4k Battery Replacement: step 4, image 3 of 3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Battery Replacement, Motherboard Removal: step 5, image 1 of 2 Brightsign 4k Battery Replacement, Motherboard Removal: step 5, image 2 of 2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Battery Replacement: step 6, image 1 of 2 Brightsign 4k Battery Replacement: step 6, image 2 of 2
    • Lift the motherboard out of the casing.
  7. Brightsign 4k Battery Replacement, Battery: step 7, image 1 of 2 Brightsign 4k Battery Replacement, Battery: step 7, image 2 of 2
    • Flip the motherboard over.
    • Desolder the two solder joints and remove the melted solder.
    • Beware of over heating the soldering kit will damage the logic board.
  8. Brightsign 4k Battery Replacement: step 8, image 1 of 3 Brightsign 4k Battery Replacement: step 8, image 2 of 3 Brightsign 4k Battery Replacement: step 8, image 3 of 3
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
    • Pull the battery from the motherboard.
Tuong Ngo
85 Reputation
1 Guide authored
USF Tampa, Team S17-G6, Boczar Spring 2018 Member of USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 441
