Brightsign 4k Heat Sink Replacement
  1. Brightsign 4k Heat Sink Replacement, Outer Shell: step 1, image 1 of 3 Brightsign 4k Heat Sink Replacement, Outer Shell: step 1, image 2 of 3 Brightsign 4k Heat Sink Replacement, Outer Shell: step 1, image 3 of 3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Heat Sink Replacement: step 2, image 1 of 3 Brightsign 4k Heat Sink Replacement: step 2, image 2 of 3 Brightsign 4k Heat Sink Replacement: step 2, image 3 of 3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Heat Sink Replacement: step 3, image 1 of 3 Brightsign 4k Heat Sink Replacement: step 3, image 2 of 3 Brightsign 4k Heat Sink Replacement: step 3, image 3 of 3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Heat Sink Replacement: step 4, image 1 of 3 Brightsign 4k Heat Sink Replacement: step 4, image 2 of 3 Brightsign 4k Heat Sink Replacement: step 4, image 3 of 3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Heat Sink Replacement, Motherboard Removal: step 5, image 1 of 2 Brightsign 4k Heat Sink Replacement, Motherboard Removal: step 5, image 2 of 2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Heat Sink Replacement: step 6, image 1 of 2 Brightsign 4k Heat Sink Replacement: step 6, image 2 of 2
    • Lift the motherboard out of the casing.
  7. Brightsign 4k Heat Sink Replacement, Heat Sink: step 7, image 1 of 2 Brightsign 4k Heat Sink Replacement, Heat Sink: step 7, image 2 of 2
    • Flip the motherboard upside down.
  8. Brightsign 4k Heat Sink Replacement: step 8, image 1 of 3 Brightsign 4k Heat Sink Replacement: step 8, image 2 of 3 Brightsign 4k Heat Sink Replacement: step 8, image 3 of 3
    • Remove the black adhesive that covers the four screws.
    • Remove the four screws.
    • Flip the motherboard over and remove the heat sink by pulling up.
Mattison Collins
85 Reputation
1 Guide authored
USF Tampa, Team S17-G6, Boczar Spring 2018 Member of USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 239
