Brother CS6000i Sewing Light Replacement
  1. Brother CS6000i Sewing Light Replacement, Body: step 1, image 1 of 2 Brother CS6000i Sewing Light Replacement, Body: step 1, image 2 of 2
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Sewing Light Replacement: step 2, image 1 of 2 Brother CS6000i Sewing Light Replacement: step 2, image 2 of 2
    • Pull the white cover off.
  3. Brother CS6000i Sewing Light Replacement: step 3, image 1 of 2 Brother CS6000i Sewing Light Replacement: step 3, image 2 of 2
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Sewing Light Replacement: step 4, image 1 of 3 Brother CS6000i Sewing Light Replacement: step 4, image 2 of 3 Brother CS6000i Sewing Light Replacement: step 4, image 3 of 3
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Sewing Light Replacement, Sewing Light: step 5, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the single 16 mm Phillips #2 screw.
    • Remove the metal plate.
  6. Brother CS6000i Sewing Light Replacement: step 6, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two 16 mm Phillips #2 screws.
    • Remove the metal plate underneath screws once screws are removed.
  7. Brother CS6000i Sewing Light Replacement: step 7, image 1 of 1
    • Use a standoff tip to remove the 10 mm Phillips #2 screw directly next to the lightbulb.
  8. Brother CS6000i Sewing Light Replacement: step 8, image 1 of 1
    • Disconnect the light connector from the PCB.
  9. Brother CS6000i Sewing Light Replacement: step 9, image 1 of 1
    • Remove the light.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Aidan Lear
130 Reputation
1 Guide authored
Cuesta, Team 20-1, Krynen Fall 2024 Member of Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 226
