Introduction
This problem often occurs with the Brother printers mentioned above. It can have two causes.
With the paper drawer removed, disconnect the printer from the mains for 30 seconds and then reconnect it to the mains while holding down the power button. If the printer then starts, the capacitor on the main circuit board is defective and must be replaced. Matthias Loikasek has nice instructions on how to do this here: https://de .ifixit.com/instructions/Brother+MFC-J44....
If the printer no longer powers on, then the power supply is defective and must be replaced. I will show you how to do this in the following repair instructions.
Disconnect the printer from the power supply, then open the cover under which the USB port is situated. There are corresponding recessed grips on the side surfaces of the printer.
To remove the cover holder, pull out the sliding piece at the rear end (picture 2). The holder can then be pulled out upwards.
Before we separate the cover from the printer, the two cable connections must be disconnected. To do this, remove the cover by lifting it on the right side.
Now pull off the two cables (picture 2). If it is difficult, you can carefully use flat-nose pliers.
The cable holder, which is rotatably attached to the cover, is lifted upwards and then the cover is pulled out to the rear.
Once the cover is removed, you can see a total of 6 Phillips screws that must now be unscrewed.
The cover can then be removed upwards.
The metal module that contains the power board can be seen on the bottom of the printer on the right. In order to be able to pull this out, the plug in the first part (Figure 2) is removed and the wires are carefully pulled out of the holder, preferably with tweezers.
The front left printer cover is removed by loosening the snap connection with a screwdriver in order to access the second screw connection of the power module and to unthread the cable.
Thread the cable out of the brackets at the front.
As shown in Figures 2 and 3, the two Phillips screws must be removed, however be careful not to lose them by accidentally dropping them into the depths of the printer.
After derouting the cable and releasing the clamp connection by pressing on the metal bracket, the module can be pulled out downwards (Figure 1).
Pull the cable off the circuit board. In order to reassembly everything correctly, note how the cable is routed through the metal housing.
Unlatch and remove the metal cover by lifting the tab.
Remove the grounding screw from the power plug and remove it with the cable from the holder (Figure 2). The two cable routing parts are only plugged onto the metal carrier. For the installation it is important how the cable is routed to the circuit board (image 3)
Remove the screws on the circuit board. The new circuit board can then be installed.
Follow the steps in reverse order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
2 Comments
I didn't have to replace anything (yet). I just followed the instructions and the printer came online and worked as it is supposed to.
THANK YOU.
Sue Kleiman, USA
Great help here is a few extras.. On step one there is a clip at the back of the arm where the red arrow is on the diagram, you need a small screw driver to bend the clip forward to release the arm holder downwards, its hard to see it. When the arm is released you then lift the lid to 90 degree as the lid pivot point has flats sides on them so can slide out of there sockets and the lid and scanner will lift away.
When you get the power board out there is a soldered fuseon it so check that first it might only be that.
In general if the fuse has blow its probably the Mosfet transistor on the board that has short circuit. (or something else) My fuse was blown and it blow again when I replaced it. Mosfet and diodes gone, these cost about £15 if you want to repair board, but i got used board for £20.
This page help me so i took the time to add to it Thanks
