Brother IntelliFax-2840 Control Panel Replacement
  1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: step 1, image 1 of 1
    • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
  2. Brother IntelliFax-2840 Control Panel Replacement: step 2, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 2, image 2 of 2
    • Gently pull the ADF up and away from the machine.
  3. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: step 3, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement, Control Panel: step 3, image 2 of 2
    • Gently lift up the control panel.
  4. Brother IntelliFax-2840 Control Panel Replacement: step 4, image 1 of 3 Brother IntelliFax-2840 Control Panel Replacement: step 4, image 2 of 3 Brother IntelliFax-2840 Control Panel Replacement: step 4, image 3 of 3
    • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
    • Repeat for the left side control arm.
    • You can make this task easier by taking the handset out of the cradle and setting it aside.
  5. Brother IntelliFax-2840 Control Panel Replacement: step 5, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 5, image 2 of 2
    • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
    • Lifting from the front edge, gently flip up the control panel.
  6. Brother IntelliFax-2840 Control Panel Replacement: step 6, image 1 of 1
    • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
  7. Brother IntelliFax-2840 Control Panel Replacement: step 7, image 1 of 1
    • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
    • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
  8. Brother IntelliFax-2840 Control Panel Replacement: step 8, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 8, image 2 of 2
    • Separate the rear control panel cover from the control panel.
  9. Brother IntelliFax-2840 Control Panel Replacement: step 9, image 1 of 2 Brother IntelliFax-2840 Control Panel Replacement: step 9, image 2 of 2
    • Gently pull the control panel cable straight out from its connector.
    • The control panel should now come free.
Geoff Wacker
92,145 Reputation
89 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 18
All Time: 4,461
