Brother MFC-490CW Front Panel Replacement
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: step 2, image 1 of 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: step 2, image 2 of 3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: step 2, image 3 of 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
To reassemble the front panel, follow these instructions in reverse order.
2 other people completed this guide.
Matt
64 Reputation
2 Guides authored
UMass Dartmouth, Team 4-4, Miles Fall 2014 Member of UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Members
11 Guides authored
1 Guide Comment
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 2,047
