Brother MFC-490CW Wireless module Replacement
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: step 2, image 1 of 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: step 2, image 2 of 3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: step 2, image 3 of 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: step 3, image 1 of 1
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: step 4, image 1 of 3 Brother MFC-490CW Wireless module Replacement: step 4, image 2 of 3 Brother MFC-490CW Wireless module Replacement: step 4, image 3 of 3
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: step 5, image 1 of 2 Brother MFC-490CW Wireless module Replacement: step 5, image 2 of 2
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: step 6, image 1 of 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: step 6, image 2 of 3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: step 6, image 3 of 3
    • Separate the two clips that hold the module in place.
    • Lift up the module.
To reassemble your wireless module, follow these instructions in reverse order.
Matt
64 Reputation
2 Guides authored
UMass Dartmouth, Team 4-4, Miles Fall 2014 Member of UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 2,193
