Brother PT-1010 Cutter Blade Replacement
  1. Brother PT-1010 Cutter Blade Replacement, Remove Back Cover: step 1, image 1 of 1
    • Open the back cover of the device by pressing on the indication arrow and pulling it open.
  2. Brother PT-1010 Cutter Blade Replacement, Locate Cutter Blade Unit: step 2, image 1 of 1
    • Locate the yellow cutter blade unit as shown in the photo.
  3. Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: step 3, image 1 of 3 Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: step 3, image 2 of 3 Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: step 3, image 3 of 3
    • Using your thumb and forefinger, pull up, applying a small amount of pressure until the blade loosens and comes out.
    • Be very careful when pulling out the cutter blade, it is very sharp.
    • The Brother no. TL 5 Cutter Blade Unit is required for replacement.
Haley Sweet
460 Reputation
4 Guides authored
Baylor, Team 4-4, Williams Fall 2014 Member of Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,400
