Brother Printer DCP-L2540DW Toner Cartridge Replacement
  1. Brother Printer DCP-L2540DW Toner Cartridge Replacement, Toner Cartridge: step 1, image 1 of 1
    • Pull the center paper tray extender to expose the drum unit.
  2. Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 2, image 1 of 1
    • Gently pull the drum unit out of the printer at a slight incline angle.
  3. Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 3, image 1 of 2 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 3, image 2 of 2
    • Push down on the lever lock to unlock the cartridge from the drum unit.
    • Remove the cartridge from the drum unit and recycle it.
  4. Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 4, image 1 of 2 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 4, image 2 of 2
    • Unpack the new toner cartridge from its packaging.
    • Gently shake the cartridge to evenly distribute the toner throughout the printer transfer roller.
  5. Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 5, image 1 of 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 5, image 2 of 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 5, image 3 of 3
    • Remove protective cover enclosing the printer transfer roller
    • AVOID CONTACT WITH PRINTER TRANSFER ROLLER. This could potentially damage the device.
    • Insert the new cartridge in the drum unit.
    • A click should be heard to acknowledge the toner cartridge has been fitted properly.
  6. Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 6, image 1 of 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 6, image 2 of 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 6, image 3 of 3
    • Clean the corona wire with the slide tab near the front side of the drum unit by sliding it left and right several times.
    • Return the slide tab back to its original position before continuing.
  7. Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 7, image 1 of 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 7, image 2 of 3 Brother Printer DCP-L2540DW Toner Cartridge Replacement: step 7, image 3 of 3
    • Insert the drum unit with the new toner cartridge attached at a slight incline back into the printer.
    • Remember to have the drum unit pushed in enough for the front cover to be able to close.
    • You have now successfully completed replacing the toner cartridge for your Brother DCP-L2540DW Printer.
Garvish Patel
145 Reputation
1 Guide authored
One Comment
I have done this process and the printer is still telling saying that we need to put in toner?? Can not figure out why?? Any help??
Ed Reinstein - Reply
Past 24 Hours: 2
Past 7 Days: 38
Past 30 Days: 201
All Time: 5,804
