Brother XR-40 Back Panel Disassembly
  1. Brother XR-40 Back Panel Disassembly, Back Panel: step 1, image 1 of 1
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Back Panel Disassembly: step 2, image 1 of 1
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Back Panel Disassembly: step 3, image 1 of 1
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Back Panel Disassembly: step 4, image 1 of 1
    • Remove the bottom panel.
  5. Brother XR-40 Back Panel Disassembly: step 5, image 1 of 1
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
5 other people completed this guide.
Allison
302 Reputation
2 Guides authored
Cal Poly, Team 2-12, Amido Winter 2014 Member of Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 80
All Time: 11,899
