Brother XR-40 Stitch Select Knob Replacement
  1. Brother XR-40 Stitch Select Knob Replacement, Back Panel: step 1, image 1 of 1
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Stitch Select Knob Replacement: step 2, image 1 of 1
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Stitch Select Knob Replacement: step 3, image 1 of 1
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Stitch Select Knob Replacement: step 4, image 1 of 1
    • Remove the bottom panel.
  5. Brother XR-40 Stitch Select Knob Replacement: step 5, image 1 of 1
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Stitch Select Knob Replacement, Stitch Select Knob: step 6, image 1 of 1
    • Adjust the knob to gain access to the phillips head screw.
  7. Brother XR-40 Stitch Select Knob Replacement: step 7, image 1 of 1
    • Remove the 14mm Phillips #2 screw.
  8. Brother XR-40 Stitch Select Knob Replacement: step 8, image 1 of 1
    • Remove the knob.
Kevin Bickers
673 Reputation
4 Guides authored
Cal Poly, Team 2-12, Amido Winter 2014 Member of Cal Poly, Team 2-12, Amido Winter 2014
CPSU-AMIDO-W14S2G12
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,464
