Buick Key Fob Battery Replacement
  1. Buick Key Fob Battery Replacement, Remove the Inner Key: step 1, image 1 of 1
    • Push the chrome button on the back of the key fob to release the inner key
  2. Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: step 2, image 1 of 2 Buick Key Fob Battery Replacement, Separate the Top & Bottom Shells: step 2, image 2 of 2
    • Using an opening tool/pick helps avoid damage, however you can also use the inner key to pry the two shells apart
    • If using the inner key to pry them apart, just reinsert the tip of the key into fob and gently twist
  3. Buick Key Fob Battery Replacement, Remove Old Battery: step 3, image 1 of 1
    • Slide a tool underneath the old battery to pop it out, the replacement battery goes in face down toward the bottom shell
Jim
331 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 47
All Time: 733
