Bush Pump Head and Handle Replacement
  1. Bush Pump Head and Handle Replacement, Head and Handle: step 1, image 1 of 2 Bush Pump Head and Handle Replacement, Head and Handle: step 1, image 2 of 2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Head and Handle Replacement: step 2, image 1 of 2 Bush Pump Head and Handle Replacement: step 2, image 2 of 2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Head and Handle Replacement: step 3, image 1 of 2 Bush Pump Head and Handle Replacement: step 3, image 2 of 2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Head and Handle Replacement: step 4, image 1 of 2 Bush Pump Head and Handle Replacement: step 4, image 2 of 2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Head and Handle Replacement: step 5, image 1 of 3 Bush Pump Head and Handle Replacement: step 5, image 2 of 3 Bush Pump Head and Handle Replacement: step 5, image 3 of 3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Head and Handle Replacement: step 6, image 1 of 1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
Jake Devincenzi
117,485 Reputation
57 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 178
