CASIO CDP-230R Main Circuit Board Replacement
  1. CASIO CDP-230R Main Circuit Board Replacement, Panels: step 1, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement, Panels: step 1, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement, Panels: step 1, image 3 of 3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
  2. CASIO CDP-230R Main Circuit Board Replacement: step 2, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 2, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 2, image 3 of 3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Main Circuit Board Replacement: step 3, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 3, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 3, image 3 of 3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Main Circuit Board Replacement: step 4, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 4, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 4, image 3 of 3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
  5. CASIO CDP-230R Main Circuit Board Replacement: step 5, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 5, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 5, image 3 of 3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Main Circuit Board Replacement: step 6, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 6, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 6, image 3 of 3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Main Circuit Board Replacement: step 7, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 7, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 7, image 3 of 3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Main Circuit Board Replacement: step 8, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 8, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 8, image 3 of 3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
  9. CASIO CDP-230R Main Circuit Board Replacement, Main Circuit Board: step 9, image 1 of 2 CASIO CDP-230R Main Circuit Board Replacement, Main Circuit Board: step 9, image 2 of 2
    • The main circuit board is located on the green side of the button panel. The main circuit board is the smaller green board.
    • Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver.
  10. CASIO CDP-230R Main Circuit Board Replacement: step 10, image 1 of 1
    • Lift the main circuit board from the button panel.
  11. CASIO CDP-230R Main Circuit Board Replacement: step 11, image 1 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 11, image 2 of 3 CASIO CDP-230R Main Circuit Board Replacement: step 11, image 3 of 3
    • Grip the white plastic end of the orange and white cables that is attached to the right side of the main circuit board and pull to the right.
    • Repeat for the orange and white cables attached to the left side of the main circuit board and pull up.
2 other people completed this guide.
Gavin Chao
191 Reputation
1 Guide authored
Cal Poly, Team S4-G2, Livingston Fall 2017 Member of Cal Poly, Team S4-G2, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G2
4 Members
6 Guides authored
2 Comments
Уважаемый fixit это димитрий фенетов твой чертовски мертвый
Roman Ambramovich - Reply
дорогой ifixit ваша ложь не является исключительной
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 36
All Time: 1,802
