CASIO fx-50FH II Scientific Calculator Battery Replacement
  1. CASIO fx-50FH II Scientific Calculator Battery Replacement, Battery: step 1, image 1 of 1
    • To turn the calculator off, first press the "shift" button.
    • Release the "shift" button, then press the "AC" button.
  2. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 2, image 1 of 2 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 2, image 2 of 2
    • Place the calculator face down, then use a Phillips #00 screwdriver to remove the single screw securing the battery hatch in the top right corner.
  3. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 3, image 1 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 3, image 2 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 3, image 3 of 3
    • Push the battery hatch to the right until it slides off.
  4. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 4, image 1 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 4, image 2 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 4, image 3 of 3
    • Put on a pair of protective gloves before handling the battery to eliminate the risk of chemical burns.
    • Insert the tip of a spudger into the indent on the right-hand side of the battery to lift the edge of the battery up.
    • Lift the battery up and out.
  5. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 5, image 1 of 1
    • Inspect the battery compartment any alkaline residue.
    • If no residue is present, skip to Step 7.
  6. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 6, image 1 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 6, image 2 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 6, image 3 of 3
    • Use a cotton swab dabbed with white vinegar to wipe the alkaline off the battery compartment.
    • Use a dry cotton swab to remove the vinegar and alkaline residues.
    • Let the battery compartment dry completely.
  7. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 7, image 1 of 1
    • Insert a new LR44 1.5V alkaline button battery into the compartment, with the positive sign facing up.
  8. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 8, image 1 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 8, image 2 of 3 CASIO fx-50FH II Scientific Calculator Battery Replacement: step 8, image 3 of 3
    • Reattach the battery hatch by sliding the hatch in from the right to the left.
  9. CASIO fx-50FH II Scientific Calculator Battery Replacement: step 9, image 1 of 1
    • Use a Phillips #00 to secure the screw.
You have successfully replaced the battery of  a CASIO fx-50FH II Scientific Calculator!
Cheuk Wai Chan
196 Reputation
1 Guide authored
2 Comments
Very nice guide! I found the pictures to be very good and corresponding to the steps very well.
Frank Loi - Reply
Thank you for the steps. I followed the steps and managed to salvage my calculator which I almost had to throw away. This has helped reduce waste. :)
Nancy Yeo - Reply
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 66
All Time: 2,020
