CCM Ice Skates Steel Blade Replacement
  1. CCM Ice Skates Steel Blade Replacement, Steel Blade On CCM Skates: step 1, image 1 of 1
    • Place the palm of one hand over the laces at the middle of the skate boot.
    • Close that palm and firmly grasp the skate.
    • Use the other hand to grab and remove any skate guard.
  2. CCM Ice Skates Steel Blade Replacement: step 2, image 1 of 1
    • Place the heel/back portion of the skate on the table.
    • Firmly grasp the toe of the skate with one hand.
    • Insert the flat head screwdriver from a multi-tool into the groove of the first screw and hold.
  3. CCM Ice Skates Steel Blade Replacement: step 3, image 1 of 1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the first screw.
    • Turn the flat head screwdriver in a counter clockwise rotation until it is loose.
  4. CCM Ice Skates Steel Blade Replacement: step 4, image 1 of 1
    • Remove the loosened screw from the white plastic blade holder.
    • Insert the screwdriver into the fastener and apply pressure to remove the fastener.
  5. CCM Ice Skates Steel Blade Replacement: step 5, image 1 of 1
    • Insert the flat head screwdriver from a multi-tool into the groove of the second screw and hold.
  6. CCM Ice Skates Steel Blade Replacement: step 6, image 1 of 1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the second screw.
  7. CCM Ice Skates Steel Blade Replacement: step 7, image 1 of 1
  8. CCM Ice Skates Steel Blade Replacement: step 8, image 1 of 1
    • Wrap a hand in a cloth towel.
    • Pinch the two flat sides of the metal blade between the thumb and index finger.
    • Do not touch the bottom or edges of the blade.
  9. CCM Ice Skates Steel Blade Replacement: step 9, image 1 of 1
    • Apply pressure to the sides of the blade with your fingers.
    • Slowly pull the blade upward.
    • To avoid injury, do not pull the blade up in one quick motion.
Steven Marcyan
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 6,042
